custom control color changes
I need to change a boolean control color based on certain cases. This is simple, I would normally just wire up a color array to the boolean property node and set the false color to be green, yellow, or red (whichever was needed). However, the control needs to be trapezoid shaped. Is there a way to change the shape of the control without importing images from clipboard? If I copy a custom image from clipboard, it is placed over the boolean control so the properties will be useless (i.e. the user can't see them). What would be best is if I could just take the normal, rectangular boolean images and make select parts of it transparent so it takes on a trapezoid shape. Suggestions?
Message 1 of 11
(6,451 Views)
can you post the trapezoid shaped item so that it can be tried?
Regards
Guru (CLA)
Message 2 of 11
(6,429 Views)
The only way i can think of customizing the boolean with edit control and making the part equal to the back ground color.
Message 3 of 11
(6,423 Views)
Something like this
Message 4 of 11
(6,421 Views)
Accepted by topic author GregFreeman
My tag ...
LabVIEW_Control_Customize
Includes the thread "How to customize a control using Labview " where you will find a step by step proceedure to do this.
Ben
Message 5 of 11
(6,411 Views)
muks wrote:
Something like this
Yup, thanks muks and ben. Perfect
Message Edited by for(imstuck) on 03-11-2010 08:45 AM
Message Edited by for(imstuck) on 03-11-2010 08:47 AM
Message 6 of 11
(6,403 Views)
I'm having the same issue as the other guy. When I copy the image, it loses trasparency. I'm using 8.5. I saved as a wmf, but the only way i can find to import it is to change to "tweezer" mode (forget the exact name) and right click. But when I do this, it overwrites the normal boolean image for that particular state. Is there another way to import the wmf file?
Message 7 of 11
(6,392 Views)
Solved...When you copy and save it to the clipboard, it saves as a bitmap. This wont hold transparency. I saved as a *.png and all you have to do is drag the file and drop it on the customize control screen. This will import it as a png and preserve transparency.
Message 8 of 11
(6,379 Views)
yeah i know i had to work a lot better to become a ben....:smileywink:
Message 9 of 11
(6,358 Views)
😉 Don't we all. Now I am having a problem...again. When I overlay the image, I click the boolean but its not registering for some reason. Am I just brainfarting here? If I click real fast, eventually it gets it. It's set to latch when released and is a type def.
Message Edited by for(imstuck) on 03-12-2010 10:45 AM
Message 10 of 11
(6,344 Views)
