curve fitting gives input, at the output
As I said, use the polynomial fit function, no need to guess initial parameters.
Here's a quick rewrite.
Message 11 of 19
(1,485 Views)
Accepted by topic author alican
And if you want to see the fit curve with a higher resolution, use polynomial evaluation, e.g. as in the attached modification.
Message 12 of 19
(1,480 Views)
thanks a lot Altenbach.
Message 13 of 19
(1,456 Views)
Hi Altenbach,
Could you tell me, what should i do, if i want to see frequency on x achse, not values between -1´to 4.
Message 14 of 19
(1,439 Views)
it is done, now.
Message 15 of 19
(1,429 Views)
I am in a desperate need of help for curve fitting of my data i.e failure rate. Please if anybody can help me I am also willing to pay. Thanks.
Message 16 of 19
(1,268 Views)
Start a new thread and explain what you want to do, what you tried, and where you got stuck.
Message 17 of 19
(1,265 Views)
hi I am sorry to get back to you later. Is it possible to contact you by any means? I wanna have a very small session with you to explain my issue and my requirements.
Message 18 of 19
(1,253 Views)
The forum is for solving programming problems such that future users with the same problem can benefit too. I don't give personal advice that remains secret because the long time benefit is not there and it is a disservice to the community.
If you feel you cannot discuss your problem in public, look into the NI alliance partner network and hire somebody.
Curve fitting is typically a simple problem and only a very small aspect of a project. Is everything else working fine?
If you want to solve it on your own, here are some resources. You might also want to look at my NI-Week 2017 presentation about data fitting.
Message 19 of 19
(1,248 Views)
