convert string to 1D or 2D string to write in Spreadsheet
I have a String to write in Spreadsheet. I need to convert that string to 1D or 2D so that it can be compatible with the input of Write to Spreadsheet file.vi
I am using string type for this VI instead of Integer.
Thanks.
Message 1 of 13
(4,631 Views)
Is the string a single text value or is mutiple values separated by some delimiters? If it's just a single, just use the build array and wire it to the 1D input. Spreadsheet String to Array can be used for anything else.
Message 2 of 13
(4,628 Views)
These are multiple values sapretade by space and tab. Build array does not accept string as input. Please correct me if i am wrong.
Message 3 of 13
(4,614 Views)
Bhandi wrote:
... Build array does not accept string as input. ...
Wrong!
Build array does accept a string as an input.
Ben
Message Edited by Ben on 09-01-2009 01:48 PM
Message 4 of 13
(4,607 Views)
Hi, look at this example. I hope that it help you.
Message 5 of 13
(4,605 Views)
What about when the text in the string is separated by \n (new line)? I´ve tried build array but just get the first line.
Message 6 of 13
(3,968 Views)
This is an old thread and your question makes very little sense without additional context. Please start a new thread and give more details. Attach your code if possible.
If the string is already formatted with delimiters, simply write it to a file using "write to text file". It seems silly to invoke "write to spreadsheet file" if you only have a single element.
can you show us your code? Where does the string come from?
Message 7 of 13
(3,965 Views)
Hey,
I want to append the multiline string (as a single cell) to a excel sheet containing other info. The other columns of my .xls contain 1D strings built into an array,  so I cannot append my string directly. I tried to "build array" first which just gets the first line of the multiline string. Then I tried with Trim Whitespaces with the same results. 😕
Message 8 of 13
(3,958 Views)
Your code has nothing to do with excel. You cannot use delimiters inside your your array elements that use reserved delimiters.
Message 9 of 13
(3,949 Views)
