connect to webservice
I can connect to my localhost but when I try to connect to my webservice from another computer it will not work
this is what I use:
http://"My IP Address Here(The IP address of the computer with the program):8080/WebService/3/4
I get a connection error. I have deploy the webservice and everything made sure that I am correct on the link and still I get a connection error
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 1 of 29
(4,083 Views)
Did you check your Firewall?
Message 2 of 29
(4,049 Views)
Harold Timmis,
As jojp mentioned have you check your software and NAT firewall settings?  Have you disabled any antivirus on each machine?  Are you able to ping the host machine from the target machine?  Can you see the host machine from the target machine through windows (network computers)?
Sam K
Message 3 of 29
(4,039 Views)
Yes to all your questions I check them, I figured it out everything works fine
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 4 of 29
(4,035 Views)
The URL should be something like http://yourserver/ServiceName/ViName/value1/value2
You seem the have missed one part either "Servicename" or "ViName".
Please check NI-DSM for the correct path to your service.
Message 5 of 29
(4,030 Views)
Can you please explain how you achieved this?
I am having the same problem.
Message 6 of 29
(3,879 Views)
You need ServiceName and VIName
Message 7 of 29
(3,873 Views)
Thanks for your reply jojp:
I have put those, since I am able to connect from a browser on the same pc, but when I use a different PC (on the same network), it says url not found. firewall is off, and I can ping the development PC from the second PC.
Any ideas?
Message 8 of 29
(3,864 Views)
Check the Access Settings in LabVIEW (VI Server & Webserver. for testing set all to *.
For security you can change the permissions back to single ip addresses later.
Message 9 of 29
(3,860 Views)
I did as you suggested but still no luck. Do I have to install some drivers on the client side?
Message 10 of 29
(3,852 Views)
