09-15-2011 08:11 AM
did you use something like 127.0.0.1 oder localhost on the server pc where it worked or did you use the public ip address to test?
09-15-2011 08:15 AM
Check to browser settings for proxys.
Maybe on both computers only the own ip adress is excluded, so the second test computer browser will try to access via a proxy.
09-15-2011 08:18 AM
Have you checked that you specified the Port number (usually 8080 if not explicitely changed) to the URL?
Olivier L. | Certified LabVIEW Developer
09-15-2011 08:19 AM
On the server PC both the localhost and the internal IP work well, when I put the external ip on my server PC, I get a "Could not connect error"
09-15-2011 08:21 AM
Olivier:
Yes the port is set to 8080, and I've used in the URL (ip:8080/servicename/viMapping)
09-15-2011 08:23 AM
Watchout for nasty proxy settings
09-15-2011 08:35 AM
I checked for proxy settings, and no proxy is used for the browsers on both PCs.
I am running out of options
09-15-2011 08:40 AM
Double check -> options -> web server -> browser access -> browser acces list = * && "allow viewing and controling" is set
09-15-2011 08:43 AM
I double checked, all is in order.
Do I have to configure my router for it to work?
09-15-2011 08:47 AM
You said that you entered external IP adress on serverPC, is this normal?
I think your server PC get your webserver.
Then your client PC ask your webserver with the URL, and your webservice answers with datas. Am I wrong?
