connect to webservice
Settings look good.
IP-Address (or external ip or public ip) is the same from every computer you access there service.
On the server PC which runs the Web service you can additinally use 127.0.0.1 or localhost to access the service.
Message 21 of 29
(1,186 Views)
I tried to connect to the webservice using a browser on my server, and used the external IP of the server just to test, but it did not work.
Message 22 of 29
(1,186 Views)
Can you see the Service in the Distribute Service Manager? Not only under localhost, but also under you servers name?
Message 23 of 29
(1,184 Views)
In Options -> Web Server -> Advanced Settings -> IP Address of listeners you have to choose "Listen on all net addresses"
Message 24 of 29
(1,176 Views)
1. I can see the service in  Distribute Service Manager under my server name and local host.
2. I cannot find  Advanced Settings in web server options
Message 25 of 29
(1,171 Views)
Sorry i´m still using LabVIEW 2009 😉 Options might be renamed since in recent version.
When it appears in Ni DSM, than your usually almost there.
Install a small webserver and try to fix your router settings until you can reach it.
Then start again to use LabVIEW Webservice
Message 26 of 29
(1,168 Views)
I will try to do what you suggested.
I will post back if I get any luck.
Thank you for your time jojp
Message 27 of 29
(1,165 Views)
I renabled the firewall then disabled it again and now it works.
Also to be able to connect from an external network, I had to forward the 8080 port to the IP of my server.
Message 28 of 29
(1,159 Views)
Thanks for giving feedback.
Message 29 of 29
(1,149 Views)
