connect 1d array of strings to an input string terminal
Can i just do 3 nested for loops and iterate them 27times.
Message 21 of 40
(2,275 Views)
Yes.
Message 22 of 40
(2,266 Views)
Need help finishing this code.
Message 23 of 40
(2,249 Views)
Wow, that's just one big mess, creating a 27x27x27 3D array (~20000 waveforms!) and some 2D array and 1D arrays, etc.! I would really recommend to start with the tutorials mentioned before going any further.
Basically, you need two stacked loops and no duplicate file IO code (all code is in the innermost loop). One loop has 3 iterations and the other has 27 iterations. You get the 2D array out, no reshaping necessary.
Message 24 of 40
(2,243 Views)
ugh fine are there any other tutorials i need to know about other than the ones before.
Message 25 of 40
(2,238 Views)
Those weren't enough?  If you are looking for any more than those you'll likely need to take a course.  Contact your local NI sales rep to find training in your area.
Message 26 of 40
(2,231 Views)
im in college and they dont teach labview so this is the only help im getting. i dont have a sales rep.
Message 27 of 40
(2,190 Views)
Does this look right now?
Message 28 of 40
(2,189 Views)
Still have some work to do.
What's the point of the third loop?  That isn't needed.
Why the Get TMDS Propperties?  You aren't getting anything out of it.  Get rid of it.
Your outter loop should be iterating 3 times, once for each module.  And use that value to build up your channel name.
Use Indexing Tunnels on both of your FOR loops.  That will create a 2D array of waveforms for you.
Message 29 of 40
(2,179 Views)
one question using the percent sign for the channel name is there any way we can get it to start for 0 instead of 1.
Message 30 of 40
(2,157 Views)
