connect 1d array of strings to an input string terminal
the thing is is that i need to split up 81 channels into groups of 3. would i just do the same thing.
Message 11 of 40
(2,120 Views)
I don't understand what you mean. What is "groups of 3"?
How many graphs do you want? Are all 81 channels in the same file?
Message 12 of 40
(2,114 Views)
yes there are 81 channels in 1 file so each graph should show 27channels each. so still 3 graphs.
Message 13 of 40
(2,110 Views)
There are still many possibilities. Do you want # 1, 4, 7... etc or 1..27 in the first graph.
In any case, if the channel names just differ by a number, create the channel name based on the iteration terminal of the loop. Then you could reshape the resulting 1D array to a 2D array with three columms, index out the columns, and graph them. It really would not add much to the existing code.
Message 14 of 40
(2,102 Views)
i see so i want 27 channels on 3 graphs. so would i change the number on the array to 3.
Message 15 of 40
(2,098 Views)
I have no idea what you are saying.
Message 16 of 40
(2,091 Views)
Here is one possibility ...
Message 17 of 40
(2,088 Views)
I guess im saying i dont know how to change the code to get what i want. I want 3 graphs with 27channels on each one. there are 81 channels on the tdms file. how do you change the array from a 1D to 2D.
Message 18 of 40
(2,086 Views)
I said "reshape"! 😄
Message 19 of 40
(2,081 Views)
ohhh I see now. The program is changing the number of Modules i have not the number of channels. I want to seperate the channels from each module on 3 graphs.
Message 20 of 40
(2,076 Views)
