connect 1d array of strings to an input string terminal
I am trying to connect 1D array of strings output to a strings input but it will no let me.
Message 1 of 40
(6,122 Views)
Accepted by topic author reggie2016
An array of strings and a string are very different things. Your arrays seem to contain only a single element, so insert an "index array" to get that element as a plain string.
Where do these string array diagram constants come from? If it is just a diagram constant, grab the element and move it out of the array container, then delete the array container.
Message 2 of 40
(6,114 Views)
From what to what are you trying to connect?  There are way too many possibilities in the example you gave us.
Message 3 of 40
(6,109 Views)
And what exactly are you trying to do here?  There is no need to open a file 3 times in parallel.  Just open it once and do whatever reads you have to with the same reference, preferable in series.  You might even be able to just use a FOR loop to do all of your reads.
Message 4 of 40
(6,100 Views)
I just added an index array and it works good now.
Message 5 of 40
(6,097 Views)
im not that good at labview quite yet to put it in for loops and stuff like that.
Message 6 of 40
(6,094 Views)
what i am trying to do is read the data collected from my daq modules and display them on three different graphs.
Message 7 of 40
(6,091 Views)
If you are new to LabVIEW here are some tutorials when you get some time.
NI Learning Center
NI Getting Started
-Hardware Basics
-LabVEW Basics
-DAQ Application Tutorials
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
As for you issue specifically.  An understanding of what the data represents is important, and knowing this will likely answer your question for you.
Lets say you have a single analog reading of 5 volts.  This is a scalar double.  Now you want to graph it so you grab the Waveform Graph and put it on the front panel.  But when you wire your 5V reading to the graph it says you need to provide a 1D array.  This makes sense when you realize the graph is intended to display many values at once, not just one value.  This is why it wants an array of values to put on the graph all at once.
A single reading can be turned into an array using the Build Array function, but it is still just a single reading.  If you wired your 5V reading to a build array then to the graph it would run, but what would you see?  Nothing because the graph can't display a single point of data, it needs multiple values.  So you could try to build previous 5V readings into the array so you have multiple values to display at once.
Your situation is similar, you need to understand why you have a 1D array of strings, and you need to understand why your function needs a single string value.
Message 8 of 40
(6,067 Views)
Here's how you would use a FOR loop. No duplicate code! 😉
Message 9 of 40
(6,065 Views)
you make this look super easy.
Message 10 of 40
(6,058 Views)
