complex demodulation
I've incorporated the unwrap phase vi where u suggested and the spikes have gone, however, there is still a problem when I ran it through simulated data (two sine waves of different amplitude (20 and 50) and frequency (0.1Hz and 0.25Hz added together). When I set f0 (the frequency I want to demodulate) to, let say 0.25Hz, sure enough I get the correct frequency output, but when I change f0 to say 0.50Hz the frequency output does drop to 0, but instead stays at 0.5 and the spikes appear again. I have attached the VI's with simulated data saved. this is getting confusing!
Message 11 of 13
(809 Views)
by the way, thanks for you help so far, I'm fairly confident the amplitude side of CMD is working,, its just the frequency demodulation isn't quite right...
this is one of the VI's running in the program that i forgot to attach
Message 12 of 13
(809 Views)
Hello Alain,
Do you have the Complex Demodulation Example in a Labview 6.02 format. I do not have version 6.1 yet.
You can email it to me (<2MB) at
vangoengineering@earthlink.net
Thanks.
Vinson Go
Vango Engineering
Message 13 of 13
(809 Views)
