how do i get the right colormap for my image?
After I acquire a color image from my pci1411 frame grabber, I have an image object (name and pointer). The image was created using "IMAQ Create.vi" with RGB set as the image type. If I want to display this image, I can use "IMAQ ColorImageToArray.vi" and "Draw True-Color Pixmap.vi" to get a decent representation on my monitor. But if I want to save it as a jpeg, I have only the function "write JPEG File.vi" for writing a flattened pixmap to a jpeg file. This function requires a colormap as an input. My question is how do I get a color map to use as an input to this function?
jc
Mac 10.4
LV7.1
CLD
(3,139 Views)
Can you post a simple version of your code? I assume you are using LabVIEW 6.1 because the LabVIEW 7 VI does not have a colormap terminal on write JPEG File.vi .
(3,139 Views)
After investigating the vi's inside the "write JPEG File,vi" I found that it requires an empty colormap array if the image is a color image. Leaving this terminal unwired is not an option. It returns an error when unwired. It suffices to right click the colormap terminal and pull down to "create->constant". The constant created in this way is an empty colormap array.
jc
Mac 10.4
LV7.1
CLD
(3,139 Views)
Wow. Who would have thought that an empty color map would have solved the issue. Thanks for letting us know you found an answer.
(3,139 Views)
