compare and extract number from string
My meanning is: if I have a number, eg, 347750 and then i need to extract the nearest greater number-in the example is: 347760 and then the same line rate I also need to pick is: 0.45%( pls see the attach jpg)
btw, how to extract the float number and percentage number from the string.
thanks
Message 11 of 18
(1,477 Views)
Could you please send a text file with that data set in.
I will try out my code on that and then post it.
Many thanx
AdamB
NIUK
Applications Engineering Team Leader | National Instruments | UK & Ireland
Message 12 of 18
(1,474 Views)
Pls see the TXT file and wait for your help.
Message 13 of 18
(1,468 Views)
This was so much easier than the original problem posted.  Here go LabVIEW 7.1.1
Message Edited by Pana-man on 10-14-2005 06:40 AM
Paul
Message 14 of 18
(1,460 Views)
Thanks Paul
I got it.
Message 15 of 18
(1,452 Views)
Hi srt,
I also had a go, but reading from a file.
I assumed you might want the actual line of the file so I have added that in too.
Hope this helps
AdamB
Message 16 of 18
(1,448 Views)
Many many thanks Adam
Message 17 of 18
(1,442 Views)
Paul, Many thanks for your many helpful VIs. I am pretty new to LabView so I have a simple question for about serial port out. I am reading this set of info from a digital multipurpose thermometer.
1+17
1+17
1+17
1+17
1+17
2+34
2+34
2+34
2+34
2+34
3-2.3
3-2.3
3-2.3
3-2.3
3-2.3
etc. each of the first repeating characters represent temperature, pressure, dew point etc. and the second set represent the real value. how do i sort this string and display it?
Thank you
Message 18 of 18
(1,120 Views)
