cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
Events based on Properties of Controls
An example of what I'm trying to accomplish:
Consider trying to create an event that triggers when the user changes the Max or Min of the Range of a Slider control.
I'd rather not have to poll the control's range to detect the value change. I would much prefer to have an event registered for it.
Mensagem 1 de 4
2.873Exibições
How does your user change the Min/max settings for a slide in a running program/vi ?
I cann't do it.
Mensagem 2 de 4
2.872Exibições
A similar question was asked at LAVA recently.
Long story short, poll the properties, then fire a user event.
Ton
My LabVIEW Ideas
Mensagem 3 de 4
2.862Exibições
I cann't do it.
If you select the text of the scale at the top or bottom you can enter new values.  Theses entered values are then applied as new min or max limits.
There is no direct access to an event when the min or max limits change (You could post this on the Idea exchange)
This snippet demonstrates one method of generating events by polling the silder
"Should be" isn't "Is" -Jay
Mensagem 4 de 4
2.860Exibições
