‎02-24-2008 11:47 PM
‎02-24-2008 11:51 PM - edited ‎02-24-2008 11:56 PM
I'm sorry to say, but it can't be done. Background color is a property of the control that makes up the array. It can't be individually set for each element of the array. The only differences allowed between different elements in an array is there value, not any property node setting.
You're options, assuming the array isn't too large, would be to make a cluster that has a numeric for each element of the array. You can use some cluster to array and array to cluster functions to work with the data. But it won't allow you to enlarge the array at runtime.
Another option would be to use a table or multicolumn listbox.
‎02-25-2008 12:27 AM
‎02-25-2008 02:36 PM
