NI vision
Hii
    I am having a NI vision based vi. In that some vision based files were missing like IMAQ Histogram,Partical analysis,Morpology.. see i have already installed NI vision builder and IEEE 1394 driver also..Then whats a problem??
(2,773 Views)
Hi senthil,
The IMAQ Histogram, Partical Analysis, and other image processing VIs are installed by the Vision Development Module (VDM), not the IMAQ or IMAQ for IEEE 1394 drivers.  Please make sure that VDM is installed and activated and reply back if you are still unable to load these VIs.  You can check that it is installed and activated using the NI License Manager utility.  The VDM will show up as "NI Vision" and should have a green box next to it if it is activated.
I hope this helps.
Rishee B.
(2,735 Views)
