code cannot measure current
The labview code to get transfer and output characteristics for a mosfet does not seem to measure the current of the mosfet test sample. The .csv file generated shows current as 0. can someone tell me what is wrong with it?
bhuyanashima_0-1757424581152.png Output characteristics
bhuyanashima_1-1757424753133.pngTranfer characteristics
(1,058 Views)
We cannot debug or analyze pictures.
You have two code "islands" that run in parallel, what are they supposed to do and in what order? The sequence structure on the left has no purpose.
(1,053 Views)
in output characteristics, the top code does voltage-current sweep and the bottom one applies gate voltage simultaneously. the same is true for transfer. i am attaching the code.
(1,046 Views)
(1,026 Views)
Can you see current data on the graph as well ?
(1,001 Views)
That I can see. But it's not getting recorded
(981 Views)
