clipboard
hi, how can i read a image from the clipboard and display it in a
labview-panel? (i can read and display .bmp files)
thx
Message 1 of 10
(6,211 Views)
hi Alfred,
find attached an example with pict ring.
I have opened jpeg-pictures I took during the flood last week in Dresden/Germany - in this case with photoshop.
Then copy this picture as if you want to paste it somewhere. Then go to LabVIEW - on your frontpanel should be placed a Pict Ring. Right click on this Pict Ring and paste your picture with "Import picture". If you want to add more pic's look to the menue around this action.
Regards
wha
Message 2 of 10
(6,208 Views)
thank you, but i do not just want to watch the picture, i also want to
process ist. maybe i did not explain what i am searching for exactly. i want
to analyze the actual screen output from a program, this means i need a
pixmap-array from the actual windows screen. at the time i solve the problem
by using a captureprogram, wich saves the actual screen to a bmp-file, then
i read it again in labview. this solution is very slow and instable and has
high disk load wich is not necessary. i want to grab the screen directly of
simulate a pressing print key (works) and read from the clipboard (my
problem).
in nidevzone i found a example for labwindows, that allows to read a image
from clipboard into an array, and there is a IMAQ ClipboardToImage function
in the lab
view help, but i cant find the function.
thx for help
"wha@atmel" schrieb im Newsbeitrag
news:506500000005000000AD9A0000-1027480788000@exchange.ni.com...
> hi Alfred,
> Regards
> wha
Message 3 of 10
(6,208 Views)
This is also what I need. Can anyone give us a sample code? Thanks. -Jianmin
Message 4 of 10
(6,073 Views)
Try Image Toolbox at:
    http://www.geocities.com/gzou999/imgtool.htm
George Zou
Message 5 of 10
(6,060 Views)
I have LabVIEW 7 and there are no block diagrams so it doesn't work for me. Thanks. -Jianmin
Message 6 of 10
(6,056 Views)
Sorry, demo only available in 6.1 for now.
George Zou
Message 7 of 10
(6,054 Views)
Import Bitmap demo is available for LV7.1 at:
George Zou
Message 8 of 10
(6,024 Views)
How can i remove the Clipboard from the VI Hierarchy..??
the cilp boarding is giving the path to the subvis..
So the sub Vi is getting  its Access  slowly , When Called in  main VI..
regards
TIJU
Regards
Tiju Thomas
Message 9 of 10
(5,297 Views)
The clipboard appears in the hierarchy if there are any VIs in it. You can remove the VIs by copying something else into the clipboard (like a constant).
Even so, this should not cause the VI to run slowly.
If you still have a question, you should start a new thread and describe your problem accurately, preferably with some code.
___________________
Try to take over the world!
Message 10 of 10
(5,275 Views)
