Application builder fails because VIs are still in memory
When I build an executable using Application Builder for LabVIEW 6.0.2 I sometimes get the message "The following VIs are still in memory and need to be closed before continuing", although I have closed all VIs related to the executable and the only VI open is an empty one. The only solution I find is to close LabVIEW and restart it. Is there a simple solution.
(3,481 Views)
Hi TSST
I also have experienced this problem. And closing LV seems to be the only way for doing this. I did not find anything more elegant 😞
Pawel
(3,481 Views)
Sometimes a VI can stay on the clipboard after a copy-paste operation. When this happens, the build will fail. Open the hierarchy window and you will see if there is a VI in the clipboard. To clear the clipboard, just select a piece of text and copy it to the clipboard.
Also if you have designed a VI that stay running with its panel closed, it will prevent the build. Again the hierarchy window will expose the culprit.
LabVIEW, C'est LabVIEW
(3,481 Views)
Follow the attached link to an article I wrote.
It details how to solve this problem.
http://zone.ni.com/devzone/conceptd.nsf/webmain/095F19486B828D0B86256C2C0061F782?OpenDocument&node=200066_us
Its not simple until you get used to doing in this way.
(3,481 Views)
how to remove the clip board in Vi hierarchy..??
TIJU
LV 8.0
Regards
Tiju Thomas
(3,104 Views)
Duplicate and unrelated.
___________________
Try to take over the world!
(3,087 Views)
