The clipboard appears in the hierarchy if there are any VIs in it. You can remove the VIs by copying something else into the clipboard (like a constant).
Even so, this should not cause the VI to run slowly.
If you still have a question, you should start a new thread and describe your problem accurately, preferably with some code.
