center custom boolean text
Hey everybody, just a quick cosmetic question.  I have a customized OK button that has two lines of text when false, and only one line of text when true.  I'd like to center the one line of text vertically on the button, but it seems like it has to stay on the same text lineup as the false case.  Is there a quick way to do this?  If I have to get into custom picture controls and stuff, I can ignore the problem.  It's purely cosmetic preference.
(3,679 Views)
The only way I know is with indicators and visibility properties.
Jim
LV 2020
(3,673 Views)
You might be able to use an event structure and property nodes to make those chage when you change the value of the boolean...
OR an XControl instead of standard boolean with the logic to the transition in the Control itself...
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(3,670 Views)
How about adding a CR before and after the text?
Ben
(3,667 Views)
Now there's an idea
(3,642 Views)
Hi all,
I came across the same problem and want to  describe it a bit more precisely. When I change the boolean text in the value change event of this button, I notice this unwanted behaviour. But when I set the Bool- text in another frame of the event structure, all works fine. It is the same, if I unset the "Lock Front Panel..." checkmark in the event- structure dialog. For better understanding I attached a example- VI.
Another point is illustrated in the VI as well, whenever I add a "Panel Close?"- filter event, the terminal "Discard" is always shrinked. This seems to be a bug too.See picture below:
Btw. I use Lv 8.6.1.
Greets, Dave
P.S. I "solved" the problem by using the "Strings[4]"- Property, there this problem doesn't occur.
Message Edited by daveTW on 06-05-2009 01:49 PM
Greets, Dave
(3,480 Views)
