cara merubah posisi data yang didapat di notepad
saya memakai write to measurement fio untuk save data ke notepad.tapi hasil data yang didapat perbaris vertikal setiap data analog .gimana caranya biar bisa terpisah horizontal.trima kasih.
(3,443 Views)
This is the English LabVIEW forum, so please post your messages here in English.
(3,379 Views)
Google says:
"I use write to measurement fio to save data to notepad. but the results of the data obtained are vertical lines of each analog data."
Sounds like you have a linefeed after each value.  You will need to format it somehow to to use a delimiter between each value that belongs in the same row, then the last value needs to have a linefeed after it.  Usually this involves FOR loops.
Bill
CLD
(Mid-Level minion.)
(3,368 Views)
... or just change the "transpose" option. Is your data 1D or 2D?
(3,362 Views)
thanks for reply sir, i will conceive you suggest
(3,333 Views)
thanks sir, i will try it
(3,332 Views)
sorry sir, i will use english language
(3,331 Views)
