 wawan997
			wawan997
			10-30-2019 02:27 AM
saya memakai write to measurement fio untuk save data ke notepad.tapi hasil data yang didapat perbaris vertikal setiap data analog .gimana caranya biar bisa terpisah horizontal.trima kasih.
 RavensFan
			RavensFan
			10-30-2019 08:46 AM
This is the English LabVIEW forum, so please post your messages here in English.
 billko
			billko
			10-30-2019 03:51 PM
Google says:
"I use write to measurement fio to save data to notepad. but the results of the data obtained are vertical lines of each analog data."
Sounds like you have a linefeed after each value. You will need to format it somehow to to use a delimiter between each value that belongs in the same row, then the last value needs to have a linefeed after it. Usually this involves FOR loops.
 altenbach
			altenbach
			10-30-2019 04:29 PM
... or just change the "transpose" option. Is your data 1D or 2D?
11-08-2019 04:17 PM
thanks for reply sir, i will conceive you suggest
11-08-2019 04:17 PM
thanks sir, i will try it
11-08-2019 04:18 PM
sorry sir, i will use english language
