08-14-2006 07:38 AM
08-14-2006 07:47 AM
Epictetus
08-14-2006 08:46 AM
I would but it is almost exactly the same as the sample program that Ni gave out so it is not really that useful if I do
08-14-2006 08:58 AM
08-14-2006 09:34 AM
http://forums.ni.com/ni/board/message?board.id=170&message.id=79795&query.id=47839
This is what I have been reading but I can't find the dynamic files
08-14-2006 09:45 AM
hi there,
the author of the post you linked says "I'm using the report generation toolkit functions to open an excel file". the files you are missing are part of the report generation toolkit. if you don't have the rgt you could use ActiveX to write/read from excel. search the examples shipped with LabVIEW for "Excel" of how to use ActiveX.
08-14-2006 12:06 PM
I had the same issue but with excel. Try adding "_Word Dynamic VIs.vi" to your source file under Dynamic VIs and Support Files tab.. The file is in my vi.lib/addons/_office/wordsub.llb. I use excel a lot and I have to add" _Excel Dynamic VIs" to my dynamic and support files.
I am actually looking for the _Excel Dynamic VIs mentioned
08-14-2006 01:26 PM
Oh yes and I forgot to mention that my program is exactly the same as Excel Macro Example.vi
08-14-2006 01:46 PM
08-14-2006 02:14 PM
@slingee wrote:
I wonder if someone could just send me the _Excel Dynamic VIs
slingee,
As chrisger stated, those dynamic VI's are part of the Report Generation Toolkit which you don't seem to have ... so that may not be your problem.
Wild guess: Have you copied the projects.xls file from C:\Program Files\National Instruments\LabVIEW x.x\examples\comm to the directory containing your executable?
Check the online help ... it may have changed since LV6.1, but maybe not.
