LabVIEW Crash
This happened few times in last couple of weeks and I thought I should post error here. In this perticular case VI is very simple. It has 1 chart and one button.
One while loop which generates random numbers and displays on chart.I tried to change chart properties few times and tried to undo few times and thats it..
Worst part is it does not allow me to save. LV just exits after I click ok.
Error attached. (WinXP pro)
Message Edited by Sheetal on 08-08-2006 02:08 PM
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(4,455 Views)
Hi Sheetal,
I'm not able to reproduce this crahs, but I'm also running LV 8.0 and WinXP.
Maybe you can post your vi here and also which properties you change and the way you change them, so I can try!
Regards Christian
(4,406 Views)
I tried to change overlay plots/stack plots..and then undo few times..properties..it could not reproduce.
I have attached my VI.
Thanks.
CVI 2010
LabVIEW 2011 SP1
(4,389 Views)
I'm also not able to reproduce, so it seems to work well!
Christian
(4,380 Views)
Thanks for your reply.
It looks like I can't reproduce either but it DID happen.
Also, it happened few times with different VIs in last 2 weeks. May be it does not like how I work with it!
When it happens again what should I do for more information?
Thanks.
CVI 2010
LabVIEW 2011 SP1
(4,372 Views)
If it happens again let me know by posting at this thread, than i can look for further proceedings.
Christian
(4,368 Views)
Here you go.
This time..nothing on block diagram. I was just playing with picture control on front panel. Trying to paste image from clipboad..resize picture controls..undo..redo few times...and thats it..
I reproduce it few times..
Screen shot attached.
Message Edited by Sheetal on 08-15-2006 05:01 PM
Thanks.
CVI 2010
LabVIEW 2011 SP1
(4,317 Views)
