can anyone have the examples or any link which generates continuous sine wave through DAQ 6009
Can anyone have the examples or any link or attachment which gives me the idea to generation of continuous sine wave through DAQ 6009? i am just the beginner. i really want to learn it. please reply.
(3,622 Views)
Please stick with one thread!
Some basics you already should know: LabVIEW -> help menu -> Example Finder…
(3,612 Views)
that is i already know..no offence taken.anyway one more query can i use my daq 6009 as DAQmx? i am totally confused with that..if i can  use the same then how could start learning from very basics.
thanks
(3,598 Views)
Hi ritesh,
to learn DAQmx basics you should read this.
And yes: USB6009 is used with DAQmx driver…
(3,588 Views)
Thanks GerdW.:)..:)
(3,566 Views)
As GerdW already told you, the USB-6009 is only able to output one point at a time through its AO lines, and because of the limitations of USB speed, can only update the values at around 150 Hz.  This means that it is not a suitable piece of hardware to try to generate sinusoidal waveforms (unless you want to generate them at very low frequencies, one point at a time ...).
(3,557 Views)
