10-08-2015 02:58 AM
Can anyone have the examples or any link or attachment which gives me the idea to generation of continuous sine wave through DAQ 6009? i am just the beginner. i really want to learn it. please reply.
10-08-2015 03:00 AM
Please stick with one thread!
Some basics you already should know: LabVIEW -> help menu -> Example Finder…
10-08-2015 03:10 AM
that is i already know..no offence taken.anyway one more query can i use my daq 6009 as DAQmx? i am totally confused with that..if i can use the same then how could start learning from very basics.
thanks
10-08-2015 03:30 AM
10-08-2015 05:21 AM
Thanks GerdW.:)..:)
10-08-2015 05:28 AM
As GerdW already told you, the USB-6009 is only able to output one point at a time through its AO lines, and because of the limitations of USB speed, can only update the values at around 150 Hz. This means that it is not a suitable piece of hardware to try to generate sinusoidal waveforms (unless you want to generate them at very low frequencies, one point at a time ...).
