Install LV2014,but acquisition card cannot run normally.
I installed LV8.6 and acquisition card. They could run normally. Now, I install LV2014, and then the related file of acquisition card is copied to the LV2014 installation directory. But, I find I cannot use LV2014 call the acquisition card. And I used this way I can use LV2012 call acquisition card in the past. Why can not now. Isn't the LV2014 new funtionnality or I need to reinstall the acquisition card. Thank you for your help.
Message 1 of 9
(4,560 Views)
Hi qian,
what "acquisition card" are you talking about?
Which driver did you install? Which driver does it need?
Message 2 of 9
(4,535 Views)
Assumption: DAQmx device, but DAQmx was not installed for LV 2014.
Norbert
Norbert
Expert: Geometry
Message 3 of 9
(4,524 Views)
Thank you very much. Acquisition card is ADLINK acquisition card called "DAQ-2005". I have successfully installed acquisition card driver. The card support LV after version 6.0.
Message 4 of 9
(4,513 Views)
Does it work now?
Norbert
Norbert
Expert: Geometry
Message 5 of 9
(4,509 Views)
Thank you very much! I use ADLINK acquisition card called "DAQ-2005". When I used LV2012 I can call this card. But now, I find I cann't. Does that mean the new version does not support the card ?
Message 6 of 9
(4,504 Views)
@qianmoluoxiao wrote:
[...] Does that mean the new version does not support the card ?
This is a question Adlink should be able to answer. Did you check their web page for updated drivers?
Norbert
Norbert
Expert: Geometry
Message 7 of 9
(4,497 Views)
Thanks your help.
Message 8 of 9
(4,481 Views)
Thank you very much. My computer install LV8.6 and LV2014. I can use LV8.6 call the card, but I cannot use LV2014 call it.
Message 9 of 9
(4,476 Views)
