call DOS-based exe file
I have a DOS-based EXE file. When run it at DOS command window, it needs input 2 parameters at two rows respectively.
Now I want to call this exe file in Labview, How do I do?
I tried System Exec.vi, but I dont know how to pass the two parameters in the "stand input".
Detailed, my dos-base exe file runs at DOS command window like this:
c:abc.exe (click carriage return)
Input parm 1: a1
Input parm 2: a2
In the "command line" of the System Exec.vi, I can put "abc.exe", but how I can put the two input parameters "a1" and a2 at the standard input.
Thanks.
RED
(3,115 Views)
You can pass your parameters i the command line, like if you were calling the app in the dos prompt.
So you can make abc.exe a1,a2.
Hope this helps,
Paulo
(3,109 Views)
Thanks for your reply. But I still can not pass the two parameters in "command line" of System Exec.vi. For example, in the command line I put "abc.exe a1, a2", the DOS window was opened, still prompting me input a1, a2. Then another strange thing happened, when I input a1, a2, the DOS exe file seems not execute and quickly returns to Labview panel.
Do you know what should I do?
(3,109 Views)
Check the following: http://forums.ni.com/ni/board/message?board.id=170&message.id=123429
Paolo
Paolo
(3,078 Views)
Have you tried using /codes? /r for return??? I haven't tried that but I don't have an exe that is looking for params like yours.
-Brett
(3,059 Views)
