How to show differences between vi files?
Is there some way to show the differences in the block diagram between two vi's, say for example between the current and older version? In other languages, I compare the source files using WinDiff.
(2,629 Views)
Yes, go to "tools...compare...compare VIs".
(2,627 Views)
And just to add a little bit of info, this feature is only available with the Professional version of LabVIEW. Also, the VIs have to have different names.
(2,622 Views)
