camera in labview
i'm using a camera in labview to take multiple shots in a running experiment. i want to save these pics. to a seperate folder to do some image analysis. any clue as to where i should start?
(3,438 Views)
That depends on how you're getting the picture. If you're using standard LV picture format, the picture palette (in the Graphics & Sound palette) has VIs for saving to 3 different formats. If you're using IMAQ, there are probably VIs there as well.
If this didn't help, tell us what you've got already.
___________________
Try to take over the world!
(3,426 Views)
i'm using IMAQ to get the pictures. as the camera takes new snapshots, the previous one gets replaced..so i want to save each one as it comes into a new folder. any suggestions as to how to start and where i should look? thanks!
(3,417 Views)
If you have the full IMAQ Vision library installed you should have VIs in the IMAQ palette under Motion&Vision->Vision Utilities->Files.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,405 Views)
Hi Lana,
In order to save the file to a different path, you will want to use the IMAQ Writefile VI found on the functions palette under NI measurements > Vision > Vision Utilities > Files. On the path input, specify the location in which you would like to save the image.
Hope this helps!
Robert
(3,376 Views)
Thanks everyone! i've got it saving pictures now and i'm just starting to look at some of the image processing features from vision. but thanks again. ^__^
(3,365 Views)
