04-14-2017 05:18 PM
Hello!
In my cRio Primary Disk Free Space is only 16 KB (total capacity is 488 MB). Is there any way that I can check what consumes this amount of space? I have installed only few software components (I'm attaching a list).
04-14-2017 06:05 PM
If you installed the FTP or WebDAV components, you could use one of them to look at what is on the disk. Well, you have the 2011 install, so it would just be FTP. So use FileZilla or some other FTP client to dig around.
04-14-2017 06:08 PM
Are you running any RT code that saves data locally?
04-15-2017 06:22 AM
crossrulz
I had examined the disk and that is what I got:
/tmp - 70,4 MiB
/ni-rt/system - 390,1 MiB
/ni-rt/startup - 0 MiB
/ni-rt/LabVIEW Data - 0 MiB
ni-rt/config - 4,9 MiB
If I delete /tmp folder, I don't loose any important data?
/ni-rt/system/www - consumes 246,7 MiB, is that right?
altenbach
No, I'm not.
