cRio Primary Disk full
Hello!
In my cRio Primary Disk Free Space is only 16 KB (total capacity is 488 MB). Is there any way that I can check what consumes this amount of space? I have installed only few software components (I'm attaching a list).
(3,414 Views)
If you installed the FTP or WebDAV components, you could use one of them to look at what is on the disk.  Well, you have the 2011 install, so it would just be FTP.  So use FileZilla or some other FTP client to dig around.
(3,389 Views)
Are you running any RT code that saves data locally?
(3,385 Views)
crossrulz
I had examined the disk and that is what I got:
/tmp - 70,4 MiB
/ni-rt/system - 390,1 MiB
/ni-rt/startup - 0 MiB
/ni-rt/LabVIEW Data - 0 MiB
ni-rt/config - 4,9 MiB
If I delete /tmp folder, I don't loose any important data?
/ni-rt/system/www  - consumes 246,7 MiB, is that right?
(3,331 Views)
