Split array of clusters
How can I split an 1D array of a cluster of two elements?  I am trying to use a chart graph with two sets of data and I want to get the amplitude of one of them with the chart history.  Here is an example of what I am trying to do.  I know it is probably really simple but I can't figure it out. Can anyone point me in the right direction?  Thanks
(5,829 Views)
(5,822 Views)
Use a For loop with autoindexing at the array of clusters, unbundle the element, autoindex on the outgoing value.
But in your case, you should probably be just looking for the max in the overall loop and store the result in a shift register you compare on every iteration rather than operating on the entire chart history every time.
Message Edited by Ravens Fan on 02-05-2010 11:50 AM
(5,816 Views)
You may want to vote for this idea.
(5,807 Views)
Thanks Dennis
(4,984 Views)
(4,978 Views)
