cRIO embedded web
Dear all,
I am trying to make a web server with my cRIO project. After doing as some instruction on the internet I have done.
But when I try to connect my *.html... it shows as following:
(I have installed LV runtime 2015 from http://www.ni.com/download/labview-run-time-engine-2015/5504/en/)
Please help me because this is the first time I work with cRIO
Thanks all,
(3,671 Views)
It looks like this is a simple message saying that you have already downloaded the RTE. Does your program run as expected if you ignore the download? What are you attempting to do inside that box on the first screen shot? Is the second screen shot what you would expect? I would select the third option and also check the box to "Remember my selection and don't show this dialog box again"
(3,617 Views)
two photos show two different browsers.
Now I have updated my IE to latest version.
And I have post the problem here...
Coul you help me?
http://forums.ni.com/t5/Real-Time-Measurement-and/Remote-Panel-doesn-t-show-the-VI/td-p/3282319
Thank you so much
(3,581 Views)
