[cRIO] WEB SERVER ERROR
HELP ME!!
Dear all,
When I try to test an app with web server, I configured some setting in Web Configuration from NI-MAX.
At first, the address is : http://169.254.4.42/bla bla...
But after my setting, I change to localhost (as picture below) and the Web Configuration in NI-MAX also be disabled.
Please help me how to fix it!
(4,250 Views)
This often occurs if your cRIO has inconsistent IP settings. Check the status of your device in MAX to confirm this. If that’s the case I recommend taking a look at this KnowledgeBase article. It suggests removing and re-adding the target in MAX or configuring it to use a static IP address.
(4,205 Views)
I have already fixed it by formatting the cRIO and reset all setting to default. Thank you so much
(4,175 Views)
