cDAQ-9178 driver specific?
You have the correct drivers, maybe you have a bad installation.
Message 11 of 16
(967 Views)
It seems almost the same installation but there is one obvious difference, the NI DAQmx ADE Support is 21 in the upper image and 24Q3 in the lower. That’s likely from your attempt to install DAQmx 21 but installing an older version over a newer one should only be possible if you remove the newer one first. That DAQmx installation seems confused and I would attempt to first deinstall at least DAQmx completely and then reinstall it. Possibly you may have to deinstall all NI drivers and do a reinstallation.
Rolf Kalbermatter  My Blog
Message 12 of 16
(959 Views)
I would rather have everything the same on both machines as much as possible. I have uninstalled everything. The only thing left is the package manager. Is this a good starting point to reinstall?
Message 13 of 16
(944 Views)
I would rather wipe the machine clean than rely on uninstall-install as there will always be some residue.
Santhosh
Soliton Technologies
Message 14 of 16
(940 Views)
On my package manager it only shows the package manager as installed. Should I look elsewhere?
Message 15 of 16
(935 Views)
Accepted by KMC123
Reinstalled everything. All is good now! Thanks everyone!
Message 16 of 16
(908 Views)
