05-02-2017 02:04 AM
Hello,All
I have a question about my c-DAQ 9174 USB chassis. When I start to run labVIEW to collect data, the active LED become green and start to blinking. Is it normal? Meanwhile, sometimes, when I start to run labVIEW, the active LED become solid green. Are both blinking green and solid green shown the device works fine?
Thanks.
05-02-2017 02:36 AM - edited 05-02-2017 02:37 AM
Hi lh,
why don't you read the manual of your device?
(Typically green lights indicate "good" conditions…)
05-02-2017 03:34 PM
Hi,GerdW
Thanks. I have read the user manual before. But I did not find anything that was explained that when the active LED was blinking. Do you have some suggestions?
Thank you
05-02-2017 03:39 PM
