LAbView timestamp format conversion
Hi
Got your contact from your post in community.
I need your help in converting the time stamp format of LABVIEW. I am right now getting the data in seconds elapsed w.r.t 1904 (e.g. 3576256122.245), but I need to convert this time stamp format to YYYY/MM/DD Hr:Min:Sec.milisec.
Would like to request, if you can suggest me something on this.
Regards
Hardeep
University of Michigan
(9,411 Views)
Accepted by topic author Hardeep
In the "Timing" folder under the "Functions" pull down on the diagram page there is a function called Format Date/Time String that will convert the timestamp to a string defined by a configuration number
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(9,400 Views)
Hi
Thanks for your reply.
(9,395 Views)
@LV_Pro Do you have any example code for this ? As I am new to LAbView, this will help me.
(9,388 Views)
Hi Hardeep,
you could go with FormatIntoString like this:
(In my experience people most often need more string formatting than just a timestamp so you could easily add more inputs to this function!)
(9,338 Views)
Thanks GerdW
(9,329 Views)
