build voice command library
as the program
http://www.mediafire.com/download/lcdhembu0b23h9e/RAHULMNAIR+SPEECHRECOGNITION.zip
via https://www.youtube.com/watch?v=aEqa-t_TWiY
how to build a personal voice recognition library?
is there any simpler programs for simple voice recognition, like several voice commands only?
(3,322 Views)
Does this question have anything to do with LabVIEW?
If so, maybe you'd be interested in LabVIEW Speak? Also see this possibly newer version.
(3,312 Views)
It is possible to build a 'personal voice recognition library' in LabVIEW, by using the windows system.speech dll.
See the below link for an example. It is worth noting that to use this method you will need to first set up Windows Speech Recognition.
https://decibel.ni.com/content/docs/DOC-4477
Al C
National Instruments,
Application Engineer
(3,241 Views)
