How to change Origin settings?
Colleagues,
Pretty simple question here. I have VI, where the Origin sticks to Bottom (I created this by placing Splitter, change settings for both panes, then remove it):
How to change this behaviour to default "Sticks to Top" without placing splitter again?
In the other words - where is the "Pane sizing" option for the "root" Front Panel's pane:
Thank you in advance,
Andrey.
(3,806 Views)
Accepted by topic author Andrey_Dmitriev
Right click on the scroll bar and you will have a Panel Sizing menu item.
(3,795 Views)
So easy.... Thank you!
(3,767 Views)
Bare in mind you need at least 1 scrollbar visable or the RCM won't activate.  And Vote here to make this even easier
"Should be" isn't "Is" -Jay
(3,754 Views)
