12-31-2018
09:38 AM
- last edited on
02-09-2026
07:20 PM
by
Content Cleaner
hi everybody
i used this paper https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHVJCA4&l=en-US for making epics client application , everything work fine but when i trying to use the application in another computer (using the exe file), he cant connect to the server (there is no error just no new data is coming)
thanks
01-02-2019 04:24 PM
Hello dborodin,
Could you please clarify, is the client unable to connect to the server, or is there a connection but no data?
Does the executable contain both the client and the server, or are you running the sever on the first computer?
Michael Pahl
01-03-2019 03:02 AM
hi thank you for your reply
there is a separate computer on the local network with epics server,the project contain only client, on the computer that the project was made the executable works good but when i activate the the executable on another computer there is no data coming from the server (i suppose that there is no connection, how can i check it ?)
thanks
