build exe file from epics client project
hi everybody
i used this paper http://www.ni.com/white-paper/14149/en/ for making epics client application , everything work fine but when i trying to use the application in another computer (using the exe file), he cant connect to the server (there is no error just no new data is coming)
thanks
(2,547 Views)
Hello dborodin,
Could you please clarify, is the client unable to connect to the server, or is there a connection but no data?
Does the executable contain both the client and the server, or are you running the sever on the first computer?
Michael Pahl
 Applications Engineer
 www.ni.com/support
(2,488 Views)
hi thank you for your reply
there is a separate computer on the local network with epics server,the project contain only client, on the computer that the project was made the executable works good but when i activate the the executable on another computer there is no data coming from the server (i suppose that there is no connection, how can i check it ?)
thanks
(2,477 Views)
