[bug] ctrl-click-drag with scroll
LabVIEW 2016 (32-bit) on Windows 7 (64-bit)
When I ctrl-click an object to copy it and drag to a position outside the visible area (causing the BD or front panel to scroll), many copies of the object are copied on top of the original.  In the attached images, I (1) created a for loop, (2) ctrl-clicked the object and dragged it to the side to a point not on the previously visible BD, and (3) went back to the first object to find multiple copies on top (moving them away to see how many were created).  It does the same on front panel objects. Anyone able to replicate?
Message 1 of 8
(4,203 Views)
Confirmed.  I was able to replicate with LV 2016.  I did not see this happen in LV 2014.
I would consider this a very serious bug as they is no indication that there are extra copies there since they are sitting dead on top.
One more interesting thing.  I tried connecting a wire to the N terminal of those overlaid For Loops.  It gave me a dialog that said. "You have attempted to connect a wire to a floating object, which LabVIEW does not allow."  I've never seen a message like that before, and have no idea how I would cause something like that to happen if I wanted to.
Since control dragging is something I do quite frequently, and certainly to put something off the edge to try to replicate another loop, there is no way I can use LV 2016 at the moment for any real code development.  This is something that needs to be fixed by an F patch, not just waiting for SP1 or LV 2017.
Message 2 of 8
(4,189 Views)
RF, Interesting.  I couldn't figure out how to even force that kind of error
Message 3 of 8
(4,148 Views)
Holy cow!!!  This used to be just a graphics artifacting where you would have "ghost" images on your BD until you scrolled them off the screen... but now they are REAL???
Bill
CLD
(Mid-Level minion.)
Message 4 of 8
(4,123 Views)
Bug has been fixed in LV 2017 beta
Message 5 of 8
(4,120 Views)
Accepted by Mancho00
I thought I had seen this come up previously in the forums around the time of 2016 release although there were a lot of problems brought up with the live update feature around the time so I may be thinking of something else. I couldn't find any related forum but CAR 606365 was filed around the September time frame which addresses this issue.
Message 6 of 8
(4,112 Views)
Update:
This appears to have been fixed in the f2 patch of 2016.
LabVIEW 2016 Patch Details
Message 7 of 8
(4,032 Views)
Just ran the update.  Fixed it for me.
Message 8 of 8
(4,013 Views)
