boolean start/reset stopwatch
Dear Labview Board,
I have a boolean that is continually changing within a while loop, and would like to measure how long it stays true.   Each time the boolean goes true, I would like to begin counting up from zero and continue until the boolean goes false.   When the boolean goes false, I would like an indicator to hold the last count until the boolean goes true again, repeating the process.
It sounds simple, but it has been surprisingly difficult for me.   I hope someone can help.
Zach
I attached a VI showing my construct... a boolean within a while loop.   It start/stops but doesn't reset.
(5,626 Views)
Hi Super Neuron,
I think this is what you need to do..
Warm Regards,
Nitz..
(Kudos are always welcome;))
(5,608 Views)
Accepted by super-neuron
Hi Zach,
This should do the job for you.
Lucither
"Everything should be made as simple as possible but no simpler"
(5,594 Views)
Brilliant.   Thanks Lucither!
(5,560 Views)
