boolean counting?
From what I can tell it's flowing correctly...the true value from the digital input case structure is flowing into the while loop...obviously I'm missing something. Explain?
Message 11 of 13
(701 Views)
after getting the 2 true values, I don't need to look at the DI anymore.
Message 12 of 13
(701 Views)
Hi skinner,
you're reading the DI only once before the loop!
But you need atleast 3 reading to detect your two rising edges, hence you need to read the DI in a loop...
Think about it!
Edit:
You know you can edit posts? No need to post two messages within one minute...
Message 13 of 13
(693 Views)
