boolean coerce to a typedef
I have a Boolean button that is typedef.  I'm doing a DOWHILE and checking that this boolean and an error cluster.  If boolean OR status is true I stop the dowhile.  The boolean button is showing a red dot...( coerce).  I can't find anything on coercing a boolean.  Do I need to worry that the boolean won't be coerced correctly?  If I do need to worry how do you coerce a boolean?
Message 1 of 23
(5,630 Views)
Is it a strict type def? I ran into this when putting a regular boolean into a strict type def boolean indicator (a custom display). Never had a problem.
Josh
Software is never really finished, it's just an acceptable level of broken
Message 2 of 23
(5,622 Views)
Taking over someone elses code.  Don't think its strict...just typedef.
Message 3 of 23
(5,610 Views)
It is..just a typedef.
Message 4 of 23
(5,604 Views)
Post an igae for use to "look over your shoulder" but I suspect LV is just reminding you about the type def... no action reqired on your part.
Ben
Message 5 of 23
(5,599 Views)
Ben
Post an image for us so we can "look over your shoulder."  But, I suspect LV is just reminding you about the type def... no action reqired on your part.
-Google translate from beneese to english.
"Should be" isn't "Is" -Jay
Message 6 of 23
(5,591 Views)
...Post an image for us so we can "look over your shoulder."  But, I suspect LV is just reminding you about the type def... no action reqired on your part.
Smiley Frustrated
After trying to find "beneese" in Google translate I came back to stare at this post. About five minutes latter I got it. Thanks for the auto-translate.
Ben
Message 7 of 23
(5,581 Views)
Ben "the typo" Rayner
Message 8 of 23
(5,566 Views)
My question is why is a single boolean a type def?  That's just another useless layer.  If you are looking for a front panel sort of thing, a normal control would do the job.
Message 9 of 23
(5,548 Views)
I can think of one reason which you can feel to free to stomp on.
As a place holder for a strict type def.
Huh?
YOu can use a strict type def to force a GUI update but not with a normal type def. So the hack goes like this;
Edit the type def on the boolean
Change its look
change it from type def to strict type def
Apply changes (since they now strict the apperence is applied to all instance)
change back to normal type def.
Save all after saving the type def.
SO you get the appearence change only when you want to apply it everywhere and you are not restricted to the rules of a strict type def.
Does any of that need translated?
Ben
Message 10 of 23
(5,542 Views)
