boolean counting?
Good morning, I'm a novice to Labview so take it easy on me. What I'm trying to do is: Run a while loop after 1 true, 1 false and 1 true boolean. I'm trying to start a measurement when a digital input off a TTL goes high the second time, so I can get a good zero reading. I've searched the forums but can't get a grasp on what I'm doing exactly. Any help would be greatly appreciated.
Message 1 of 13
(5,522 Views)
Like this?
(It's a snippet!)
Message 2 of 13
(5,513 Views)
what's the red/green icon? I've never seen that. And how would this be implemented for a while loop to run?
Message 3 of 13
(5,509 Views)
Accepted by glskinner
Hi skinner,
that's why I wrote: IT'S A SNIPPET!
Message 4 of 13
(5,495 Views)
It worked! Thank you, Gerd!
Message 5 of 13
(5,482 Views)
my only issue is that it's not counting correctly. Sometimes when the input is true, the counter reads false...and other times it reads true.
Message 6 of 13
(5,473 Views)
Hi skinner,
dunno what you're talking about...
Show your VI!
Message 7 of 13
(5,468 Views)
here it is! 😄
Message 8 of 13
(5,466 Views)
I need the measurements to run after 2 trues from the digital input
Message 9 of 13
(5,461 Views)
Hi skinner,
- using the STOP function is completely wrong here...
- you're not obeying the DATAFLOW: how will you detect any DI signal changes in your loop when you don't read in your DI signal in the loop?
Message 10 of 13
(5,460 Views)
