binary matrix multiplication
If you use booleans, why don't you use an boolean array.
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 11 of 40
(2,942 Views)
I tried your solution but there is is 2 in there in the result
Message 12 of 40
(2,934 Views)
Hi sumalama,
yes, you're working with DBL values and perform a cross product operation...
Please define your desired operation more carefully. What will be the expected result for a given input? Until now you always presented "unexpected results"...
- Please state clearly: do you want a plain element-by-element multiplication or do you want to perform a matrix cross product?
- Please provided an expected result (maybe along with some explanation of the math behind) for some example inputs!
Message 13 of 40
(2,926 Views)
Hi Sumalama,
Still uhaven't answered few questions
What do u mean by multiplicating?
can u put what values u should be getting for
0x0=?
0x1=?
1x0=?
1x1=?
and as someone already mentioned, OR is not meant for multiplication, AND is for multiplication.
uday
Message 14 of 40
(2,924 Views)
I want simple binary multiplication(AND) between the binary bits inside the array(matrix). The expected result is a matrix with binary values inside it which is shown in the figure-
Message 15 of 40
(2,906 Views)
Hi sumalama,
Your inputs are two arrays (8×3 and 3×6 "bits"), the result should be an array of 8×6 bits.
Which bits are multiplied in that "simple multiplication"?
Can you write the formula to calculate the upper left bit (index 0,0) of the resulting array? And additionally the formula for calculating the lower right bit (index 5,7)?
Message 16 of 40
(2,902 Views)
What do you mean? the array X has dimension with 8 rows and 3 column so its 8x3 array (or matrix), isn't it? and similarly goes for Y.
Message 17 of 40
(2,892 Views)
what about values at 2x1 and 2x6???
uday
Message 18 of 40
(2,886 Views)
Could anybody give me the solution to my problem. One thing is how do I get the boolean array? I cannot find it?
thanks
Message 19 of 40
(2,859 Views)
U didn't answer the previous question of how do u get values for 2x1 element and 2x6 element in ur end result.
Coming to ur latest question-create array control and then add boolean control to it u'll get boolean array.
uday
Message 20 of 40
(2,855 Views)
