not getting all required samples
Hi, I'm new to Labview and don't understand why I'm not getting all the samples I ask for.
I have a USB-6212-BNC module collecting data from 2 analog voltage inputs. I'm using ai0 for the analog trigger, using basically the same VI found as an example here: https://decibel.ni.com/content/docs/DOC-11764
The problem is that I am not getting all the samples needed. As you can see in the example below I only got ~1000 samples when asking for 2000.
(2,766 Views)
Hi bigdoug,
the output of the graph is what you get from the (missing) subVI calculation.
The DAQmxRead is configured to read 2000 samples and it surely does so as you would get a DAQmx error message instead...
Please check your subVI or attach it here with some meaningful default data!
(2,755 Views)
Yes, it looks like you are right. DAQmxRead is passing all 2000 samples to the sub VI which then discards everything from before the trigger condition is met.
Since I won't know when the trigger condition happens, the total number of samples I get out of the sub VI is not defined.
Is there a better way to acquire samples with an analog trigger? I would like to be able to define how many samples to get after the trigger. As far as I can tell the USB-6212 does not support hardware analog triggering.
(2,745 Views)
Hi doug,
you just need to read more samples after the trigger signal has been detected...
(2,739 Views)
