automatic launch impossible to disable
I'm a user of Labview since many years. Actually i'm using a 8.2 pro version to develop and build my executables. Since a few weeks, when I build my exe, they are always starting automatically, even if I disable the 'auto launch at starting' option in the exe builder. Is there any way to fix this??
Thanks in advance for help,
Chris
(3,820 Views)
Hi.
Could you make an example and send it on the forum, because it's really strange that disabling the option doesn't work?
Thank you
Best regards
(3,781 Views)
Here you have the .vi, the .lvproj, plus the .exe I made.
Bye,
(3,774 Views)
Hello.
I built the exe again and the exe didn't start at launch. I suggest you to build it again.
Best regards
(3,737 Views)
Did you perhaps install a different LabVIEW verion a few weeks ago?  It might be a little bug with the app builder (LabVIEW uses the latest installed app builder)
"Should be" isn't "Is" -Jay
(3,729 Views)
Hello.
Which version of LV do you use?If you have a professionsal edtion, LV uses the application builder related to the version of LV version you are using.
Best regards
(3,724 Views)
As I said, I'm using a 8.2 pro version. I also just realized that i've 3 different versions of the run-time on my computer (7.1, 8.0 & 8.2). Could it interfer with something??
Concerning my versions of LV, we bought a version 7 and finally we had free upgrades until the 8.2 version. I just changed my computer for a new one (winXP), so I directly intalled the 8.2 version.
I also rebuilt the exe with the lvproj mentionned above, but the result is the same, the exe starts alone....??
Thanks for your help,
Chris
(3,693 Views)
